ABS question
bugdoubt
100
May 15, 2002
Ok I guess I've been a little embarrassed to ask this but here goes. When I first bought my car the rotors were warped to heck and when abs was applied it was a nightmare. Well I figured no ABS fuse=no ABS. Well I never really thought about it again till now. Ive warped my second pair of rotors since last spring. Now I know I need to bleed my brakes but here is my question. With the abs fuse pulled is there a problem with pressures in my brake lines(assuming no air in them). Could this be a cause for warping?
I ask because I'm purchasing the Baer track kit and I don't want to ruin them by not using my ABS(i.e keeping the fuse out).
So by not having the ABS fuse in am i going to warp more rotors?
thanks:thumb:
Warped rotors are usually the result of a few common things.
- cheap rotors...crappy chinese rotors made of crappy steel warp real easy. Buy something good like Brembos
- uneven lug nut torque...puts uneven pressure on rotors. Use a torque wrench to tighten them correctly.
- hard stopping...if you're one of those guys who waits until the last second to stop and then stands on the brakes. Take it easier on the stops.
- cold water on hot brakes...the sudden temperature change causes warpage. Let the brakes cool before washing the car, etc
