MNsleeper
- Aug 18, 2012
St. Paul,
Minnesota
Anyone running a precision 6466 on a built 2.0 liter? Just wondering what I can expect for spool time!?
.Everyone I've known with Precision turbos has complained about the life span of their turbos and would not recommend getting another one.
You are correct about the Journal bearing units. The ball bearing units have had far less failures in relation. The BB failures are all user error as far as i can tell. The JB units have the most problems there was a large discussion about PTE modifying the Garrett shaft to fit their journal bearings and that is the cause of failure. although PTE blames Garrett, PTE has not ever once sent Garrett a failed unit for inspection. Garrett believes their failures are due to modification of their CHRA and or turbine shaft. Give me a min to find the article.
Garrett Turbochargers and the Truth - Yellow Bullet Forums
I owned an SCM6152 and had no problems with it what so ever at all. I loved it, sold it go go bigger.
