1g wideband (lc-1) noob -questions
toppertopper
444
May 14, 2009
edmonton, AB, Canada
Finally installed a wideband lc-1,Didn't come with the serial cable to hook it up to a comp, installed in the 02 spot (dsm link is in the mail )
It was calibrated already ..Once i installed it and started the car it reads 7.9 then goes to 21.9 :confused:
2nd do i cut pin 4 o2 and just tape both sides up ?
This is my 1st wideband experience i have no clue what to do next...Do i just wait till i get dsm link to sim ?
Are your converting to to native wideband, or are you going to use both sensors, stock narrowband as well as LC-1 wideband? Also, both the yellow and brown wires are programable.
This is what i followed for install it says nothing about what wire to connect to (pin 4 02 wire ).. Also i was reading not to connect (white wire) to pin 24 it can blow the ground track ??
Narrowband simulation install (DB gauge, Logging, ECMlink v3 setup) [LC-1 sensor placed in front o2 spot]
Red wire – 12v accessory power source (e.g. cigarette lighter or radio)
Blue wire – chassis ground
White wire - ECU sensor ground (pin 24)
Brown – ECU pin 15 (ECU Pinout - http://www.dsmlink.com/images/forums/1GECUPinout.pdf)
Yellow – DB gauge's white wire
(*Must reprogram Analog Out 1 values to match Analog Out 2 values using LM Config 3.15. Screenshots and software - innovatelc1orlm1install [ECMTuning - wiki])
Black – Calibration push button to monitoring LED to ground
*Note – The brown and yellow wires can be swapped in this scenario.
Narrowband simulation is then done inside the v3 software - v3narrowbandsim [ECMTuning - wiki]
You can do either one. It's up to you. Just because the article doesn't specifically say, doesn't mean you can't if you're getting rid of the front o2 sensor.
But I went and fixed it for anyone else who looks at it.
Not sure where you read that.
