where to run boost/vacuum feed off of BOV to
GSTurbo1
610
May 2, 2012
Pickens, SC, South Carolina
Ok guys sorry for so many post but I really need to figure out where to run my vacuum line to from my bov. I was researching and it seems that the best thing to do is to run in to somewhere on intake manifold. I was thinking of putting a tee on one of the intake manifold vacuum hoses or in between the pcv vavle and intake manifold. Let me know if this sounds good.
Anywhere on the intake manifold is fine. Some people use an un-used vacuum port (if there are any), others install a reducing "T" fitting on the brake booster or PCV lines.
I would not use the pcv because the valve is open when the engine us under vacuum soe there won't be as much vacuum in that line as there really needs to be for the bov to operate correctly.
