Firing problem on 91 tsi with 16 turbo
smelygoatcheez
Jun 21, 2012
Madera, California
Awhile ago my oil filter came of wich resulted in the balance shafts getting stuck, which in turn snapped my timing belt i have done a balance shaft elimination and re-timed and replaced the timing. it ran for about 5 hrs then it lost fire to all cylinders i replaced a few fuses and the ecm now i have fire on 1 and 4 but not 2 & 3. Really want to get this running anyone know of any solutions any input would be helpful thanks. C.J.
Run a compression test and see what the results are, I had a similar problem with my 1g. It was running fine then just stop running. I had 7 bent valves on the intake side and my timing belt was fine. I had a lifter stick up and push a couple valves into the pistons. I'm still not sure how so many got bent unless they were messed up before I got it. only one was hammered but the rest would wobble if I spun them in a drill. Also check for spark. A bad CAS can and will cause your coil pack to only fire on 1 and 4. that also happened to me just recently. Hope this helps or leads you in the right direction.
-Randy
Well i think the coil pack on the left controls 1&4 and the one on the right does 2&3 so I would think the coil pack on the right is bad. You can check it with a ohm meter.
.ok ill check all those on sunday thanks for the help ill let you all know what i find out and does anyone know any good dsm info site im kinda new to dsm i have been a muscle car guy my whole life and just now getting into turbos and stuff love them. I want to figure certain terms and things out about my car like the 16 turbo i know the stock turbo is a 14b but have no clue what a 16 is out of. Just general knowledge would be extremely helpful thanks. C.J.
this is the best dsm info site just ask any questions and well help you figure it out and do you have a small 16g or the evo3 big 16G there is a major difference
if you dont know get a picture or just write down the vin number on the turbo itself well let you know what you have any info about your car too will help us help you
okay so this is what i have found out the 16g i believe is the big 16G off the evo i remember the guy telling me that. The coil packs have been replaced about two weeks ago, which leads me to believe its the power transistor i have it out of the var im going to replace it and see ### it does thanx for all the help and if anything else turns up i will know where to go now. Oh and does anybody know any great tranny mechanics around the fresno, CA area my second went out just before the whole oil filter fiasco. C.J.
