What year shifter cables??????
2skippy
106
Mar 18, 2012
Dearborn, Michigan
Ok this problem has kept me out of my car for almost a month and I just need it solved. I have a 95 Talon TSI AWD, I have a JDM 6 bolt swap, and a 2G shifter base ( to my knowledge), I don't know what year transmission but I have a 90's mounting bracket......I bought a set of 2g turbo shifter cables of a member, put them in my car and if shifted like crap, barely could get it in gear so I took them out before I broke anything. I layed the cables next to each other and low and behold the ones I just bought are 1-1.5 inches shorter at the mounting points :banghead::banghead:.
What shifter cables do I need!!! This is a small stupid problem but it makes me wanna torch the car. If a wiseman could step in and solve this quickly I would be very grateful.
This is the stamp on the Trans.
KW5M332NPZT
ST6262
This are the cables, my old one are the longer set with the adjustable links.
Did that waiting on a reply, after some more digging I realized that I have a 90's mounting bracket on the transmission, so that would mean the 03/90-05/90 model year cable?? Since everything after 06/90 is considered 91+ which all use the same brackets/cables...
Why don't you get the correct bracket for your transmission (which is a '95-'96, by the way) and original cables? Seems a whole lot easier than swapping cables so many times.
