toppertopper
- 444
- May 14, 2009
edmonton,
AB, Canada
Whats the name of the gasket ,for the tstat housing that bolts the engine ..Went to a couple parts places today and they have no clue what i am talking about ,
I'm pretty sure it just uses silicone sealant. I know the T-stat cap (where the lower rad hose connects) takes a bead of silicone and no gasket. I don't remember using a gasket on the T-stat housing and head when building my engine, just RTV Black.
2g's use a bead of rtv, 1g's use a gasket. It is called a thermostat housing gasket. I have yet to actually find the gasket at parts stores. You will have to order it online from a vendor that sells oem parts or get it from the dealership. The part number is, MD145038.
Thank you ,thats the oneAnyone feel free to chime in (good or bad) but I make my own gaskets for things like that. Just buy a pack of various thicknesses from the autostore and bam! No more crap thin gaskets.
Oh, and the one downside is it sometimes takes a bit of time to make one correctly.
Bryan what do you use for cutting the bolt holes? I tried the socket trick but didn't turn out so good.
That's awesome, like in grade school hole punches?
Funny some of the simple things around the house can make a job go much smoother...
