How to keep water/moisture out of headlights
spadepro22
1,206
14
Mar 13, 2008
Seneca, South Carolina
I put in some hids and with the wires running out to the ballast the plastic cover that keeps the lights sealed cant be used. What are you guys using to keep water/moisture out of the lights?
You can use a rubber 0 ring, like a grommet. The only thing is to find a size that would work & and run your wires through, Done.
lowes .58 cents
Both sets of HIDs that I have, already had a grommet installed with the wires running through them. All I had to do was drill a hole in the factory plastic cover and put the grommet in place with a little silicone.
By doing it like that, won't you have to redo this application each time the bulb burns out? Hopefully you got some quality bulbs if so.
No, the application only has to be done once. If you need to change a bulb it is done just like normal. You would remove the plastic cover with the grommet in it and then be able to get the bulb out.
