602gsx
- 72
- Dec 19, 2010
phx,
Arizona
are the gaskets for the oil pump required or can i just use high temp silicone? no one in town has the gasket.. i need to special order it but dont have alot of time, so i need it now..
Oil should be used around the seal before installation correct? like I said all new gaskets where used but it's hard to belive it came bad from the factory.not to hijack this thread or anything, but I have a new rebuild with a new front case / pump & new oil filter housing, new gaskets used everywhere all with proper torque specs and for some reason I have a small oil leak what appears to be the front case crakshaft seal, only when running and when the oil gets warm..
how could this happenOil should be used around the seal before installation correct? like I said all new gaskets where used but it's hard to belive it came bad from the factory.
