Bad intake manifold gasket?
775TSI
148
Nov 8, 2009
Carson City, Nevada
Can a decent leak in my intake manifold gasket cause my car to run rich? My air fuel reads 18.0, so i am running lean but at cruise im around 14.5 to 15.5 which from what i read is ideal. i sprayed around my intake manifold after i replaced my injector and the idle damn near died. Also would this be my cause of boost loss? I am still hearing an obnoxious clicking when my idle drops low. Could this be my resistor pack for my injectors? I would unplug the injector that it sounded as if it was coming from 2 or 3, and it would stop till plugged back in. I am trying to knock away all possible reasons why my car is running like poo.
Oh i am running a AEM air fuel gauge and 18 is pegged in the red to the far right. No idea how this reads lean rich or stoich since all air fuels are different on how they read, but my numbers are ------ at idle to 14.5 - 15.5 at cruise and 11 to 10 at 9 psi under pressure.
Yes, a bad intake manifold gasket will cause you to run lean at idle/cruise, and rich under load/boost. At idle, the vacuum draws in un-metered air from the leak so the air/fuel mixture goes lean. Under boost, the high pressure air inside your intake leaks out and you lose metered air, causing the air/fuel mixture to go rich.
You pretty much pinpointed the problem when your idle nearly died as you sprayed carb cleaner around the intake manifold gasket. Fix the gasket and you're one step closer to getting your car running right.
So what about the random ticking i can hear that comes and goes but is very loud at idle? It sounds like its coming from the resistor pack / Coil pack area so right in the middle of the intake manifold. I guess you could say it almost sounds like an electrical ticking, louder then a lifter tick.
I am currently waiting to see if my CEL comes back from when it had a code for faulty circuit injector 2 (which i just replaced) and go from there. I still have not yet determined how i am getting gas in my oil hoping that the 2 injector was bad.
well just went and picked up my new intake manifold gasket, new valve cover gasket set, some new plugs, new throttle body gasket, and a new tool box since the wife ran mine over. Hopefully the car will run like a champ.
Update, While moving my tools from one box to another she managed to run over my compression checker and now the glass is cracked. This just gets better and better LOL.
Alright so last night did the intake manifold, Throttle body, valve cover and tube seals. Ran the car and it boosts hard but still only to 10 PSI but this time it doesn't drop and i don't get what feels like a decrease at high RPMs. The car idles very well around 900 and my Air fuel is between 14 and 15. I still do suspect more leaks and im replacing my plugs since these are majorly fouled.
Bad news is i still hear the obnoxious ticking coming from the injector area and when that clicking starts my air fuel goes to 18+. This does it at random and for no more then about 10-15 second intervals. Really odd never heard this before on a car other then a lifter which was a constant tick.
I have the same issue with the mystery tick, curious to see if anyone actually knows what this is and why it has an effect on a/f
how did you fix your afr going lean, i'm having the same problem, mine creeps to lean like 19.5 and when i give it a gas i goes back to normal for 5 seconds then creeps to lean again. it does this on idle and while cruising with the foot on the gas.
Lean out 0f boost could be either a vacuum leak, an exhaust leak, or a faulty O2 sensor. I would check them in that order.
i have a slight constant jerk while driving anyone answer this one? and wideband peaks lean and way lean..... i have a plx wideband the square one not round style.
My manifold absolute pressure/manifold differential pressure sensor (black sensor on top of the intake manifold) randomly clicks while driving. I can even hear it at stop lights. Anyways it tested out bad (according to the Haynes manual) Might be the "ticking/clicking" you're hearing.
I did blt and hear something hissing by the intake manifold but I'm not sure. Crack exhaust manifold could do that also? And I have pretty new o2 sensor from innovate mtxl.
