ECMlink First time tuning
turbo24
57
Feb 17, 2011
hudson, Florida
OK i have knock almost constantly and I'm not sure if its real or not the car breaks up very badly almost any time i gas it. Please point me in the right direction as I'm unsure if most of the posts apply to my oddball setup.
The UIC pipe blew off at the end and middle of two of the logs.
well i got the car running good i think i got my fuel trims pretty close any suggestions would be appreciated unfortunately i cant do any wot pulls since my stock clutch wont hang on (the stage 2 one i got was incorrect)
[/ATTACH][/ATTACH]
Readjust your tps to .63 volts
And do you have a wideband? If so log it in dsmlink as well with iscpostion.
Adjust your tps by following this video from jafromobile.
YouTube - Tuning 101 - tuning with the car off
Then after your car is warm readjust your biss screw by watching your iscpostin get it around 30.
i have my isc and fiav both blocked off .I cant seem to properly wire it since my 97 harness is nothing like any other year and cant find much information on it . I cant find much info on the effects of not using one either . I've blown out 3 throttle body shaft seals and its much cheaper to buy a T.B without these two items built into it ,so i was going to buy one of those instead of a used unit
