New parts Install, Head,cams,valves
DSMtsi23
110
3
Jan 27, 2009
Bellingham, Washington
:shhh: Striped some teeth off my timing belt and bent a few valves. Decide to just go all out since i was tearing it all down anyways.
Head-hot tanked, valve job, valves, guides, 3g lifters, decked, stock springs
DKS cams 264/272
ARP Head studs
Decided not to use the mls hg i got because i didnt have the block machined so just went with the stock composite
i thought 272 cama would beat the hell out of our stock springs and cause them to break or knock the clips off. i may be wrong but thats what i thought.
Is there a difference between intake valves and exhaust valves? Or are they interchangeable?
why shouldnt i use a mls if i dont have the block decked ?
cause you need a mirror shine surface for the MLS to seal correctly. It is muti-layered metal some with viton rubber that needs a smooth surface to seal against when compressed.
Decking of the head and block are needed or you will most likely get a HG leak of some sort.
my decked block & head and MLS with Viton rubber.
A composite gasket (soft gasket) will take form and squeeze/compress and fill in imperfections in the matting surface. The only metal in these is around the cylinder bores.
why not replace the pistons since the valves hit? thats what it looks like to me in the pic anyhow, but i get to go through the same crap with my atv dropping a valve at about 8k rpms :(
