mindset
- 1,853
- 7
- Jan 3, 2009
Brunswick,
Ohio
I'm trying to install my Intermediate Shaft but the bracket will not sit right on the block. There's still a gap on the driver side bolt. I've tried screwing both bolts in evenly, but nothing. The passenger side one will sit flush, but the driver side one has a 1/4" gap between the bracket and the block. I've searched and there is no definite answers.
Thanks.
Thanks.
and a new tap and die set. I mocked up the shaft and it held the rated 35 ftlbs spec. I also used 4 washers as a spacer.
