forcefed4
- 258
- 5
- Dec 22, 2005
Los Lunas,
New Mexico
Hmmmmm... I just noticed something. After your last pull when you are coasting, the WB still shows ~10-11:1. It should go full lean to like 18:1 until it hits your idle RPM. Your WB may be acting up.
What does it show under idle?
You also needs to adjust your TPS, it shows 2% when you are off the gas.
Add idle switch to your log.
