EVO III 16G Turbo - Help with Oil Lines
alansupra94
262
Jan 21, 2009
Wayne, New Jersey
Should I run a oil line restrictor for it? Also do you recommend braided lines or stock lines?
Thanks
Alan
Use a restrictor if feeding from the filter housing.But im assuming your sourcing from the head.
There is a restrictor in the stock feed line for 1g on the turbo side. They are plenty adequate of doing the job for mhi turbos as said and there is no need to waste the money
Well the reason I am asking is because I don't have the stock lines and I was wondering if its worth getting stock lines or braided lines.
I will be running it off the head and returning into the pan.
I was going to run the 14B but I got a sweet deal on a 16G that i couldn't pass on.
