View Single Post
Old 07-02-2009, 03:19 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #4 (permalink)
LD25Delta9 Offline
Proven Member
LD25Delta9's Avatar
Tech Posts: 166
Classifieds Rating: 0
Reputation: LD25Delta9 is more helpful than not
Well after extensive research, I guess the bore size is the same and if you are planning on boring your block anyways, you may be able to fanagle something. I would reccommend against it, however, especially if you plan on boosting it. You'd be better off just getting a built stroker kit, cause stock parts don't have the same tolerances as aftermarket. I guess it all boils down to how creative and unique you want to be.
____________________________
Adam H. GO
98RS-T B4
83Paira Feet SHO
