Quote:
Originally Posted by Sublime_06
From what I gathered reading through a few threads, I am supposed to free rev to the specific rpms as defined in the SAFC. So for example, the 1000rpm point I rev the car to 1000rpm hold it there and watch the ltft and the stft. When I did this for the first time my long term fuel trim was +12% and the stft was around +5%.. So to zero out my trims am I supposed to increase fuel on that specific rmp point until the STFT reads -12%?.. or 0?.. or what?
You'll want to add or remove fuel with the SAFC until the sum of the STFT and LTFT are as close to zero as you can get. Anything from -5% to +5% is fine.
And then repeat for all the other rpm points up to 4k, and then carry that 4k percentage onto the last few ne points?
Correct. Only because you'll probably never be in closed loop above 4k, so using your 4k point for everything else will be fine.
Thanks guys for any input. Sorry to ask a question thats been asked a few times over.
No problem. Thanks for searching first.
