MHIScan: New free DataLogger for DSMs
I got the 409.1... The cheapest one that popped up. It was 15 dollars shipped...
Ok. I found some other problems. I tried the new version and started to get errors.
It just kept trying to connect. Not even the "Stop Scan" button would stop it. I had to exit out.
But, when I tried to connect with 95-96 it worked just fine. :confused:
Hybrid doesn't work when I try Evoscan, why will it work with your program?
Using Openport 1.3U cable. It was COM 10 with my LC-1 on COM 8.
Ceddy this is some really nice work man flippin 1001+ thumbs up.
I'm not really sure on which cable would be best to order atm. I know the logger is still in beta but which is the best cable to order/use. I'm sure everyone who has read up on this wants to know what you suggest overall.
ATM i'm looking at ECMTuning's cable for 75$ that's steep but for what your logger is doing, Well Worth it. I have a 99 GSX and going to use the program asap! Thanks for making the Datalogger!
You may want a cable that will let you flash the 99 ecu if/when they figure that out.
It isn't available yet. The OpenPort 2.0 is entirely different than the ones on the market now and to reflash the 98/99 ecus you need to supply 12v to the datalink pin. In later ecus this voltage is supplied internally but with the DSM ecu it needs to be provided externally which is why the cables that exist now will not work in our cars.
Get the cheap cable that others are using and resell it or throw it away later.
Dang, that's awesome so saying later we will be able to reflash our ECU's?
If so ...hehehehe =D
btw which cable are you guys recomending i noticed Ceddy using the 409.1?? right?
I'll pick that up tomorrow if that's the correct one. The reason why i'm trying to verify is because it looks like so many ppl use diffrent cables. i'm the 99 ECU so please throw me a help line =)
16 volts to reflash.
Everyone asking about cables. The VAG 409.1 I have performs the same as my OpenPort 1.3U.
People having Initialization/Sync problems, I'm working on it.
I think there is to much variance, between different years communication speed/delays to do a polled set-up.
I'll switch back to a interrupt driven set-up. I'm still trying to find the best way to do it.
Thanks for everyones interest.
I'll suffer through the beta testing to help get this up and running. :thumb:
Thanks for all your work.
Ceddy are you working on this to be able to reflash the ecu? i've told a couple friends of mine about what your doing and they are STOKED! haha
This is great man i'd totally donate some cash to you as soon as i get everything set up!
Guys, I wanted to clarify something here. Our cable happens to work with this software, but PLEASE do not call here asking us to debug some connection issue you're having with MHIScan. If the cable installs and the device manager isn't complaining about it, then that's the best we can do. From there on, it's probably a software issue or a physical wiring issue in the car.
Thomas Dorris
ECMTuning, Inc.
LOL how does everyone like it??? Is it easy to use? Im waiting for my cable to get here... Can;t wait...
Ok I finally went out to try it in the car today. Im getting the same initialization problem as posted in the pic above.
so how many samples a sec will i be able to log with the hybrid mod on my 95 with the vag cable. i'm only getting 2-2.5 a sec with my elm323 cable. i'm still waiting on my cable from china !
Is there anyway I can use this or evoscan without a laptop? Could I like save it to a usb or something.
