SilverJester
- 95
- 1
- Aug 31, 2002
first off, I am posting in this forum because this is where I found part of my answer...but please move if it's in the wrong place.
I have a 2g which means I have 4 wires going to the TPS. the q45 tps has one pig tail w/ 3 wires and a short harnes w/ 3 wires. So far what I've been able to find is the the short harness is for the actual TPS and the pigtail is for the "idle validation circuit". I'm not sure what that means but I found it on some supra forums. I know that the difference between the 1g and 2g tps is that the the 4th wire (which ells the ecu if the throttle is closed) is seperate on a 1g. Could this be the same thing as "idle validation"?
So far this is the info I have come across as far as wired and what they are for:
q45 tps harness (not the pigtail):
-Red is the 5 volt input wire
-White is the TPS signal wire
-Black is the sensor return wire
2g tps harness:
1 - Green/Yellow (+5v Sensor Power)
2 - Brown/Red (TPS output voltage)
3 - Yellow/Red (IPS switch)
4 - Black (Ground)
Ok so I'm still a little confused on what wires to connect so if anyone has experience or more info t add I would appreciate it.
2g tps harness:
4 - Black (Ground)
at first I was like huh I thouht you were talking about the manifold. yeah I have the stock grommet I just left it out cause the wire isn't secore yet because I'm going to be running my nitrous line along with that ling but wrapped up to be safe. Once I'm done that I'll put the grommet back in. I'm more worried about getting this thing to run and see how the manifold works. I already talked to mike about his if this doesn't work out though.
.. The question is: Is it worth going for JMF mani with Q45 TB flanged? or it is NOT worth and just use my current 1G bored 63mm TB?. BTW I'll be ordering ETS 4" FMIC kit with JMF intake so if it is worth I'll go for 3" UICP instead of 2.5".
. I have all the supported parts for those turbos and I'll get the turbo setup along with the ETS 4" FMIC Kit.
