boost gauge problems
Have you checked all the hose connections? Are you still using the plastic nylon hose? What brand of gauge? Where do you have the gauge tapped into?
It is a autometer phantom series. It was tapped in between the wastegate actuator and the solenoid when i got the car and thats were i left it. It worked fine with the stock turbo and when i did the swap i hooked it up the same way and it does not register any boost.
yes when i get home i am planning on trying it in different spots. i was just looking for some answers on where to tap it in at. It just seems weird as how it doesnt work anymore from where it was at.
Thanks all is good when i hooked it up from the intake mani to the solenoid thanks alot.
But i do have 1 more concern sometimes it will blow off and the guauge says 0 it wont be a powerful blow off but you can hear it i was wondering if this is normal?
Yes that is normal. Your not producing alot of boost to blowoff but there still is some. So when the bov opens it only blows off a little bit of air compared to when your at full boost.
