View Single Post
Old 09-30-2008, 09:00 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #7 (permalink)
codyw Offline
Proven Member
Tech Posts: 46
Classifieds Rating: 0
Reputation: codyw is an unknown
I had a similar problem. When I put in a tranny I forgot to put in that (I think 12mm) bolt that goes on the backside of the tranny right above the x-fer case. I was leaking fluid from my axle seal. I noticed a little gap, maybe 1/16 of an inch between the block and trans because of that bolt missing. So I put the bolt in and it sucked the trans up tight to the block and that little bit pulled the half shaft in far enough to seal. Problem solved.
