View Single Post
Old 09-23-2008, 10:19 PM   #18 (permalink)
KGB Pilot125
Proven Member
Region: Rocky Mountain
Classifieds Rating: (0)
Reputation: KGB Pilot125 is an unknown
Quote:
Originally Posted by wishihadatalon View Post
Best 93 numbers were 33mpg for a long highway drive. The afr is around 14.7.
Best e85 numbers are 28 on the drive back from the shootout. The afr for that was 16.2. I increased timing a little for this, but after reading some different things on burn rates and what not, I should have decreased it ~2 degrees.
Do you run a Cat. Converter? I think that is really great to see some "lean burn" type tuning on here one thing that I have read about lean burn is it will destroy a cat in no time running that lean, IE hot. If you have a EGT what were the temps like while cruising?
____________________________
Josh
Offline
[posts] [blogs] Reply With Quote
Sponsored Links
