transmission bolt sizes.
BigSorn
306
16
Sep 11, 2007
Williston, North Dakota
Well, I've managed to do it..I lost 2 sets of tranny bolts. IF someone could post up what I need that would be great.. I need all the transmission to engine bolts, and the starter bolts.
thanks alot guys.
This is the best I could do.
20999Q - MD706012 - M8x60
20999U - MF140266 - M10x40
20999Y - MD740892 - M10x43.5
20999P - MF241223 - M6x12
20999V - MF140471 - M10x65
20999S - MF140021 - M8x12
I came up with these:
Above the slave cylinder bolt- http://www.dsmtuners.com/forums/drivetrain-tech/200817-transmission-bolt-size.html
2G FWD Bolt Size Wizard- ColumbusDSM - 2G Turbo FWD Bolt & Fastener Wizard
The slave bolt is the same in both links, use the 2g link as a guide. All the shaft diameters and pitches will be the same.
You can verify the bolt lentghs by measuring the transmission case and using the same thread protrusion length as the 6mm bolt above the slave. Also do this with the starter bolts by measuring the threaded ears on the starter and the matching holes in the tranny case.
Regarding the T-Case, Do the same by measuring the cases for lengths. There are 5 bolts, they are 12x1.25. Last time I needed these, I ended up going to the dealer.
20999Q - MD706012 - M8x6?
20999P - MF241223 - M6x1?
is this for a 1g or 2g?
It is for a 91-94 AWD. The 90 AWD has a different part number for one of the bolts. What cars would you guys like part numbers for?
