question about axle bracket or maybe a bracket spacer.
mitch26753
354
Aug 8, 2007
ridgelely, West Virginia
I'm in the middle of a six bolt swap. full 6 bolt in a 96 awd. My question is i got everything done except for the axle bracket. I don't have AC so i have the 7 bolt AC bracket off the car. But as i understand i need the 6 bolt ac bracket so i can use it as a spacer? Also will i only be using one hole on that axle bracket, when i say axle bracket i mean the bracket that is on the drivers side half shaft that bolts in( stock) with two bolts into the block.AS of now i have it on there(not driving the car) with only one bolt cause that is all that lines up? When i do either buy the spacer that mitsu sells of use the bracket will i use that behind the side that has a bolt thru it now?
As for that spacer i have the part number for it, but why would mitsu even make that spacer in the first place? It seems kind of weird since i wasn't aware of any dsm's that ac was a option?
