TDOH5 or TDOH6?
rogergoochman
86
Jun 24, 2003
toledo, Ohio
I know this is a 20g clearly. But I dont know if its TDOH5 or a TDOH6 20g. I went through 19 pages with the search result and didnt find a clear answer. And I also googled the numbers stamped on the housings and all that came up was mitsu 20g. Also anyone able to tell were its from i.e. buschur, fp etc. Thanks for your help and here are the pics(sorry about the quality took them with my camera phone.)
compressor housing reads 49179-54[90]0
exhaust housing reads 78-11830
my 20g td05h has a smaller hot side than the 20g td06h that I have in my closet ,that is the only difference I see in those two .
What you're asking about is the type of turbine that it has....it could be TD05H, TD06, or TD06H- the number on the compressor housing will not tell you this information. You've also failed to post a photo of the turbine wheel.
It's easy to tell the difference visually between the TD05H and TD06/06H, but very difficult to tell the visual difference between the TD06 and TD06H without removing the turbine housing and taking measurements.
The turbine is least likely to be a TD06H....they're rather uncommon. The most common would the the TD05H. If I had to guess, I'd say you have about an 80% chance that it's a TD05H, 15% chance that it's a TD06, and 5% chance that it's a TD06H.
I am pretty sure in the last 2 years he figured out what it was.
Thread is from 2008 bro .
If its a real Bushur its a TD0H6 because thats what they all used according to some research ive done on their website.
ALL Buschur 20G's use a TD05H turbine clipped 20* to 25*.
Also, Buschur does not build turbochargers....Mitsubishi builds turbochargers. Buschur buys Mitsubishi turbos then hires someone to install a DSM bolt-on turbine housing and clip the turbine, then sells it on their site at a $300-$400 profit.
