Oil Pressure Sending Unit 420a Placment...?
My96
82
Mar 11, 2003
like the title says is there such thing as an oil pressure sensor that would shut the car off if there wasn't enough oil pressure detected? something along the lines of a knock sensor???? i have a 96 n/t
I am looking to place an oil pressure sending unit and temp sending unit in-line of the oil feed but cannot find a good place to put it aside from installing another brass T-fitting off the original oil sending unit. Anyone find better placment on the 420a block...?
Unless you want to install a sandwich adapter at the oil filter, your option is at the original oil sender. Use a cross fitting or manifold instead of multiple tee's to simplify plumbing and reduce the potential for leaks.
I hate having options anyway....I now have a 3 brass-T connector conglomeration housing my turbo feed, orig sending unit, new pressure sending unit and temp sending unit...now waiting for leaks to spring up...
ok, so I just bought a 99 eclipse a lil bit ago...oil light came on, and stays on...just changed the oil last week, so Im thinking its the sending unit....where's it located at?
back of the motor right in the middle of the block. from under the car, 8 inches to the left of the oil filter and up 3 inches cant miss it
From under the car looking at the oil filter. Up and to the left of that you will see a gray plug, that's the knock sensor. To the left of that plug you will see a lime green plug, that is your oil pressure switch.
Unplug the green plug, then unscrew the 3/8" switch that goes into the block (you will need a wrench).
That is a picture if you are putting in a oil feed line too.
If you arn't putting a feed line in to then you don't need a tee. Just figure out the right adapters you need. The pressure sender is probably 1/8" npt. And the thread in the block is 3/8" npt.
So, in this picture you get rid of the stock oil pressure unit..? What do you hook up to your plug?!?!WTF
Only way I was able to take mine off was by hitting it with a hammer and screw driver, breaking that bad boy. Oh well. As long as you have an oil pressure gauge and you check your oil, they'll be no problems.
I guess some are harder then others... mine took a little tug but wasn't that hard.
You can keep the stock oil pressure switch. (You just need a different adapter then the one pictured.) But, you don't necessarily need the stock dummy light once you get a actual pressure gauge.
So, doing it this way wont give you a CEL?
heh, I learn a lot on here.
Thanks for all the information everyone, this is exactly what I needed. I have a Haynes manual that helps me but wasn't very descriptive in the location of the oil pressure sending unit... now I know.
You'll just need another 3/8" NPT Tee.
That could lead to a pretty long array of fittings coming off the back of the block, though.
I didn't like how long mine was, and I was using the setup in the above diagram.
I just ordered this fitting:
Aeroquip FBM2519 - Aeroquip AN to NPT Adapter Fittings - Overview - SummitRacing.com
Then I put the oil pressure sensor inline of the oil feed to the turbo.
Much less fittings, plus it looks a lot cleaner.
