Iddle and cruise logs
chavez408
1,115
Dec 13, 2003
Bay Area, California
what do you think?
You'll need to add LTFT Low, LTFT Mid, and LTFT High, as well as STFT. The Low will help tune your 50 Hz airflow slider, the Mid for your 150 Hz slider, and the High for your 250-400 Hz sliders.
Then once you've added them to your Captured Values list, make sure to go to Display > Values and add them to the list on the right so that you can view them.
Check out this link for instructions on how to adjust the sliders:
http://www.jeffgst.com/gmafcalibration2.html
Thanks guys, I will re post tonight or tommorow morning with new logs.
New logs are up..
Any info ###.
Your first idle log "iddlelogupdate625anza" your front o2 isn't cycling. I dont know why, but that cuases your short term fuel trims not to cycle. However your second one it is cycling fine, so who knows. Your fuel trims aren't too bad, I'd go +10% on your 50hz airflow slider, and your mid is fine for now. Do that, then drive around for a day and post a new log.
You might wanna look into wiring your fans to come on when your car is on. Your temps aren't horrible, but once you start getting into WOT tuning it will be pulling timing at 213*. Overall, you're lookin in pretty good shape.:thumb:
Cool, I'm working on the temp. I got some wrap and coating comming in for my mani. Also should I drive around for a day than iddle another iddle log?
Should I began doing WOT logs? Also, the o2 sensor is brand new so I don't know why it wouldn't cycle.
