11 Second pumpgas Big16g
Update:
Attended CCDSM's track rental yesterday. Drove the car down , made 11 passes, drove it home, no problems. Finally got that FP Race manifold on, Gotta say, it's an awesome peice. Also put on a rebuilt throttle body from Hal Landry. No real changes to my tune.
Best time was a 11.738 @ 118.52 mph. Car pulled 5 11 second passes, and the rest were low 12s. Missed 2nd a few times from too much wheel spin, but still managed 12.3-12.4's at 115mph. 17" wheels aren't really the best for drag racing...
Car is MOVING up top for a 16g car. Still on 93 octane. I think I'm shooting for 120mph traps with the cams.... Hopefully the turbo lasts though, It's been smoking I've noticed every now and then.
11.7 gee dude that is awesome. Anti lag? 2step? Anything that is helping you get these times.
2 step was set at 5500rpms. No antilag. I launch off the 2 step, but with no boost. Whenever I launch with boost, the car will not hook up , just all wheelspin. 16g makes torque instantly that launching with boost never works. NLTS the first 2 shifts, and the 3-4 I DO lift, just because it feels a lot faster to me to do it that way. Just drive the hell out of the car :D. AFR's were low 11's throughout the pass, a little leaner could of helped. Also more agressive timing could of helped too, but I didnt even bother.
Oh, it was also 80*+ out all day. I want to run on a cold street night and see what she does.
Update:
That's not the only thing smoking :p
Insane trap speed and awesome numbers!!!! Congrats man! :rocks::rocks::rocks:
With cams maybe some mid 11's with 120ish traps? On pump gas? :sneaky:
Get some (more) video of this thing too, please :)
(insert smiley here)
Why do people enjoy pushing this small turbo past its limits? It cant be too efficient after 17-19psi. I wouldnt think pushing it past its efficiency range would be helpful.:confused:
Thanks bud,
After seeing my autocross videos, it smokes a good amount, LOL. Oh well. I'm trying to get vids from the track from my friend, and I'll post any good ones.
Cams will be fun:)
I wouldn't consider 118mph "not efficent".... Just me. The car is making fantastic power, if I was past it's effiency range, I wouldn't be gaining any power.
There are a few guys that run their Evo 3's up to 30psi spikes on race gas. I'd say thats closer to the limit than I am. Honestly, I'm not running that much boost compared to other guys.
I like pushing the small turbo this hard, to prove that you don't need a big turbo to go fast. I still see LOTs of 20g, 50 trims, 30r+ guys running slower than this. What's the point? When I put my Green on, It'll run just that much harder.
What the hell is this guy talking about? WTF The E316G starts to shine at 20-22PSI.
I've been running my E316G for 2 years. It's seems plenty effecient at that psi and pulls good. But like the other guys said, it REALLY WAKES UP once you get it into the low 20's. Plus, MHI turbos have been proven to last when pushed. A fast spooling, hard hitting turbo with great street manners that can take you into the 11's. What's not to like about it?
Why not? If I had the time to invest, I'd love to start with a 14B and slowly work bigger, seeing what I can extract from each turbo.
Here's what TPG Tuning did at the track with a 16G on pump gas around 27psi:
http://www.dsmtuners.com/forums/drag-strip/262203-new-evo-iii-16g-record-et-no-no2.html
YouTube - TPG Tuning Pat @ 10.49
....and again on the dyno:
http://www.dsmtuners.com/forums/tuning-engine-management/292196-499awhp-16g.html
Now being that there are guys out there running high 11's with GT35R's, doesn't that make you re-think your turbo choice?
I think an 18g at the same PSI would be more efficient than an EVOIII. I havent bought temp probes and measured charge air temps or seen anybody who has with this turbo but more boost means more backpressure which means hotter engine which means head bolts stretch even with no knock. Thats just my opinion. I think the EVOIII is better suited for 20psi or less. An 18g will work better past 20psi for me. Call me overkill but I like for my parts to have 'excess capacity' so they last longer.
I run a CAI, a huge intercooler, a 3" exhaust and the FP race manifold seems to help with backpressure. I don't just run all this boost, I buy mods that will make it more efficent at that boost
Understandable- but it IS indeed gas which originated from a pump that was intended for use in street cars.
It is indeed pump gas, but over here we can't get it. And it's knock prevention is FAR greater than 93 octane. e85 cars will make power of race gas cars, which is awesome... But making good power on 93 octane is a lot trickier.
I REALLY want e85 out this way... Oh man:)
Wow, even thogh the temperature is rising, your lowering your times. That's awesome.
Sidebar, what size tires do you have on those EVO wheels?
  • Wanted 2g ABS - Left side harness brackets
    Looking for the metal brackets for left side ABS wiring harness. Sensors not needed
    • Justin DuBois
  • For sale 2g 2GB CAS Assembly ( Complete )
    2GB CAS Assembly ( Complete ) $85 + shipping and paypal feesYou must be registered to see element.
  • For sale 2g 2G Clock Spring, Wiper Stalk, Turn Signal Stalk
    2G Clock Spring, Wiper Stalk, Turn Signal Stalk $35 + shipping and paypal fees* removed from...
  • For sale 4G63 2G Cylinder Head
    2G Cylinder Head $250 + shipping and paypal feesYou must be registered to see element.You must...
  • Free 4G63 1G /2G ECU Connector
    Came with a parts car, 1GA Talon with a 2G ECU. Some wires look cut and spliced. I have no use...
    • Badge023
