Cant build boost with my stutterbox
tsitalon03
259
Jul 15, 2007
SouthRiver, New Jersey
Whats up guys...iight so my stutterbox is set a 5 grand and when I use it no boost builds up....but it launches just fine. I keep hearing ppl say they build 5 10 15lbs....so why cant I? I dont have any boost leaks...well no major ones. I need some feedback asap :mad:
Stutterbox does not mean antilag, all it is is a secondary rev limiter that is either speed or clutch dependent, that means it doesn't put that much load on your engine, which in turn means your turbo wont spool that much. If you aren't building even a little boost, try maybe raising it to 5500, see if that does the trick, or you could always try letting the clutch up a bit while tapping the brakes and flooring the gas with your right foot, kinda like heel-toeing, but that will kill your clutch fairly quickly. That adds load to the engine, but, like I said, isn't friendly to your clutch, it will, however, preload your drivetrain and make the launch easier on your driveshafts/differentials/transfer case.
PS-When you say no "major" boost leaks, where are you leaking? TB shaft seals?
A 2-step won't build boost like a anti-lag or NTLS switch can, but if you're holding the gas pedal to the floor you should get at least a couple pounds or so built up. I can build about 3 psi on my rev limiter with a somewhat big garrett 57 trim
Yea just a minor leak in the TB...the pedal is on the floor at 5 grand but nothing...awww well..would a maf-t help?
No, a MAF-T won't make a difference in spooling your turbo at all. What you really need to build boost is something that will add fuel and retard timing like DSMlink or some other programmable ECU/EMS
Are you sure your wastegate flapper/arm assembly is sealing shut when your not under boost? if the flap's open just a bit that could cause the loss of any spool on teh 2-step. It would also cause a later spool in the turbo in general. What RPM do you hit your peak boost at and what is your boost set at?
The turbo spools up pretty quick...i have no problem with that..right now i'm at 20psi and I get there at around 6 grand or so but i'll check the wastegate flapper tomorrow
WHAT??????? Your profile says you have an Big-16G, that thing should be making a full 20 psi before you even get to 4k RPM (even being clipped it should spool way sooner than 6 grand) , hell it should probably spool by 3500. If it seriously takes you until 6k to hit 20 psi you have MAJOR issues with your turbo and or it's wastegate and that would be why you can't get ANY boost on your 2-step
Get back to me on this one, because that sounds way, WAY wrong to me.
+1 16G variants, even big, clipped ones should never make peak boost anywhere over 4k, and even then would be laggy, if you're seeing boost at 6k something is very wrong, either a broken wastegate, a massive exhaust leak, or a dead turbo.
To test the wastegate make yourself a boost leak tester with a simple pressure gauge and then slowly pressureize the system, watching the WG actuator arm. Note what PSI it opens at. If the wastegate is broken it should pop open almost immediately.
An easy way to spot an exhaust leak would be to seafoam your engine (search it, there are plenty of threads) and then look for white smoke blowing out in the engine bay, if its bad enough to make a 16g spool by 6k then its probably a fairly large leak pre-turbo. Also, seafoaming an engine that hasn't been cleaned in a long time is just a good idea.
Finally, if neither of those tell you anything, take off your intake pipe and check the compressor wheel for shaft play, although if the shaft play were bad enough to be causing these problems then your turbo would probably also be eating through oil like it's its job and you'd have a nice little smokescreen anytime you went WOT.
Also, the wastegate could be fine, but hanging open a bit so check and see if you can close the flapper arm any further in teh closed direction. You may have to remove the actuator to see, but anything's worth finding out why you've got such poor spool performance from a 16g
Well i just got back i took the car for a spin.....yea i was waaaay off ha..20 psi hit at 3700..i guess i never actually noticed....but yea the turbo is fine
But if you arent supposed to build boost with a 2step i guess the car is fine....for some reason i always thought you were supposed build boost i heard ppl do it but i guess it was the anti lag or nlts
I beg to differ, I just got my maft setup and my turbo IS spooling faster.
Im not saying OP should get one for this reason but just thought id add that in.
Something is wrong there, if you only have a 16g.
Honestly my car builds at least 11-12lbs every time I do my 5500k stuttarbox.
But im open DP also with a couple other things that help my turbo out .....
Yo how do you build so much boost? What do you mean when you say open DP
He means his exhaust ends at the downpipe. Nothing beyond it. The lack of back pressure will help the turbo spool easier.
So if you had a turbo back exhaust you wouldnt build that much boost would you?
I was building 10 lbs of boost ~ 5500 rpm studder on a to4b 50 trim and I could get ~ 14 lbs out of a 16g.
wierd....half the ppl here say you arent supposed to build boost using a 2step...the other half says they are building boost. the guys that are building boost...do u guys have a maf-t?
I can build close to 10 psi on my small 16G with 5500 rpm 2-step. However, I also retard the timing slightly (custom EPROM), not sure how much that helps. Either way, as mentioned earlier, a MAFT isn't going to make a significant difference and you shouldn't base anything on whether someone has one more or not. You should make sure that there are absolutely no leaks, exhaust leaks, or anything else that would hurt spool and focus on that.
My old setup consisted of a 14b/fmic/exhaust/rebuilt 6 bolt car. I could build ~15 psi or so from a 5500 studder on dsm link.
I switched to a 2g car and had dsmlink/fuel mods/3" exhaust/ssac fmic/ etc and could build 10 psi or so at 5500
I now have a Ross/Manley/3065/fmic/3" gm mas/ 850's/ dsmlink/ and all the other stuff and with a 5500 studder I build 5 or so.
With antilag I build 15 +
With my antilag set at 5000 rpms I'll only build about 5 psi, but at 7000 rpms i build 15 or more. It also depends on the tune on the car. A studderbox is different than an anti-lag system so you won't see that much boost of the line.
hmmmm....i guess i'ma try and fine tune the afc and see what happens.....no boost leaks just a minor one from the tb
You have to consider that those with smaller turbos i.e. 14bs, 16gs, 50trims build a fair amount of boost and the guys with larger turbos are the ones not building much boost on just a 2step alone.
Like I originally said, It is reasonable for you to be able to build at least a good 7-10psi with your 16gs and the stuttarbox at 5500rpm and your foot planted to the floor.
Im positive its something specific to your car as to why you arent building much boost, but I have no idea as of why to be honest.
Do another boost leak test, and exhaust leak test like mentioned above.
At the end of the day, just go to the track and see how good your 60fts are.
Anyone can claim they are building X amount of boost, but all of that is pointless if there 60fts are still shit on their launches. Go cut at least a 1.8 60ft and I will tell you that you are alright and to focas on other things.
BTW, a few things that can make a car spool faster ( Some of these done on my car)
- large exhaust, a well flowing 02 housing, Fp manifold for cast mani applications over oem mani's.
- cyclone intake manifold that is properly actuated
- cam gears for I believe ''exhaust'' retard to quicken spool and shift power band
-retard ign timing more and add more fuel during stuttarbox ( pretty much anti lag )
- cold air intake ( yes this really helps.)
- gm maft setup in blow thru/ or speed density to remove restriction from in front of turbo
Thats about all I can think of, but you catch my drift.
Not to get you confused but you should be fine with that amount of boost on your studderbox. I also have a gt35r if you look in my profile and which only allows me that much. As stated above go out and try your 60ft. You shouls be able to pull a 1.8 if you clutch and tires are good and if you need any help i live in Sayreville right over the bridge.
