First log, Need help
chavez408
1,115
Dec 13, 2003
Bay Area, California
here is my first 3rd gear pull on my 14b car. Mods are below in my signature. This was all done at ****** 10 psi. It wont let me go any higher. wideband and AFPR are not install yet. How bad is it?
I set the dead time at 315. And my global % at 31, but every time I select > OK. To exit the screen it goes back to 0. Is this normal?
It would be much easier to read if you had only the 3rd gear pull (WOT from 2k RPM's to redline).
A few things I noticed:
-your coolant temps are very high
-it doesn't seem like you went WOT at all (based on your front o2 readings)
-you saw 15 counts of knock at one point
-you should log TPS volts
-you don't need to log some of those items (like mileage, torque, horsepower, and injon)
Why is your deadtime set to 315? According to this it should be around 210.
Do another pull with those changes and post it back (or in the link forums). You can also read through the links in the "getting started" thread on the link forums for more help.
hm ok. I read jeffgst's webpage and it mention that I need to set them at 315. Ill try to fix those things first. Should I log a idle run? Than a 3rd gear pull?
Hmm...I just noticed that. You could try either one and see which one works better, but I would go by the wiki site first. If you really want to know, you could send Thomas Dorris an e-mail and ask him (as well as sending Jeff a PM on here and see what he says). Either that or Nathan can chime in.
A 3rd gear pull would probably be more useful.
Is there a way you could get your wideband installed anytime soon? That would help tremendously.
The wideband is lock up in our storage and the only one that has the key is out of town. I will be installing my afpr around next week though.
So you guys suggest posting up another log that is more clearly. Ill pull a run this afternoon than.
I changed the deatime to 210 and I managed to do two more clean pulls. What do you guys think?
