I'm trying to remember whats held where, you may be able to undo the screw on the latch handle/lock assembly (under the little black square tab) and pry it enough to look around a bit. Otherwise you'll have to try a coat hanger down into the door to pop it open. You can't take the panel off with the door closed.
