Quote:
Originally Posted by casperfast
ok, one question i had about a wide band, can the factory ecu read off it? i know it doesnt bounce rich lean rich lean rich rich rich lean lean lean like a normal o2 the wideband says actual air/ fuel ratio. can the stock ecu read and understand it? would my car behave this was only until i complete a full drive cycle say a week or 2 or could it do this if i made a mistake (fu(ked up) and used a fuel additive that killed my cat and o2?
Stock ECU only reads a 0-1 volt narrowband o2 sensor signal. Widebands make a 0-5 volt signal. Basically your answer is no, stock ecu will not read a wideband. Also generally fuel additives will not kill either a narrow band or a wideband o2 sensor (especially not just one bottle). Its lead that is found in race gas that will kill o2 sensors. Most fuel additives do not contain lead.
