We are boosting at 7. All the fans and coolant stuff has already been checked. All of the vacuum lines are running to one spot off the back of the air intake. In order, it starts at the turbo then goes to the boost controller, then it tees off to the blow off valve, and goes to the back of the air intake. The boost controller does not adjust, according to my husband, and he says it should. He also said it is oil cooled. Also, what could you explain to me what "not enough timing advance for that boost level" is.
