Alright guys, it is fully installed/tested. It works great! I will get some driving videos up very soon. I also made a little plate out of sheet metal to cover the gap in the center console. I painted it flat black to match the interior.
The install was fairly easy, I just had to drill some holes in the floor and use sheet metal screws to mount it, using washers to keep it level. Then I ran the cable through the firewall in the stock hole, and then used a vice and a really big wrench to bend the stock manual control lever on the transmission ( the thing the cable attaches too). From there, I used one of the brackets that came in the kit to hold the cable, and then got some lock nuts and washers to hold the cable to the manual control lever. Here is the finished product, let me know what you think!
