Ratchet Shifter?
Our transmissions are shifted by electronic solenoids, unless you have a reverse manual valve body i dont see a point.
It is pretty useless in our transmissions UNLESS you have the RMT mod (which I have), I am putting one in because I like wasting my money on stupid things once in a while.
I bought the Hurst Pro-Matic 2 to install.
I'll show you pics in a few days when I get to my camera.
I am going to use it with the RMT Mod to manually shift at full pressure with no shift delay, that is pretty much the only reason I bought it, because otherwise it is useless. I also tried out a B&M Z-Gate shifter for a few days but didn't like it as much as the Pro-Matic 2, and the Z-gate isn't a true ratchet shifter.
I only have pics of the Z-Gate: ( it isn't bolted down or anything, I just sat it on the floor to see if it fit)
Wait till you see the promatic 2 installed, its the tits.
^Is that automatic? I broke my handle off and need a replacement, maybe i will do something like that.
Was it hard to install? Where did you get that from? Does it work right?
If I had an auto I would do it. But it is totally up to you.
