Custom front steel bumper?
Ludachris
Founder & Zookeeper
8,836
4,654
Nov 12, 2001
Newcastle, California
Since I drive the car on the street I don't want to remove the steel bumper altogether. And I'd be a little worried removing it at the track since there would be no protection for me or the engine bay. A 5 mph crash would be devastating.
So I've been thinking about having a smaller bumper made up using some round tubing or square channel. I know it might end up being a little expensive since you'd probably have to cut it in 3 pieces and welded in order to form the necessary angles but the advantages would be:
- lighter weight in the front
- more potential access to cut holes and allow airflow to the radiator/fmic
- lighter weight
- it would take up less space
Anyone tried this?
I was going to try this on my car by taking a large diameter steel tube, 3 inches, and welding to the mounts which hold the oem bumper to the frame, the cylinder like things. Then all you would have to do is drill some holes on top for the bumper to mount to. This would also be better in a crash because the the tube would slightly bend or crush itself in while the steel bumpers just move back on their mounting shafts and have very little give. This would help absorb some of the energy from the crash.
I thgouth about taking mine out altogether as well. But for the same reasons (almost) you described is why I did not. I will sacrifice that weight in order to keep the engine bay and myself a little more safe in the car on the track. Would be interested to see if anyone else has come up with any ideas such as this.
I dont see why it would be too expensive. Time consuming maybe to get the angles right. But if you are working with steel here, any welder worth his job would be able to throw some welds on it for you I would think. But maybe I am wrong here.
Would you guys think it would be stronger to have a square tube cut and welded to get the right angle or to bend a round tube piece of steel? I'm just not sure if bending it will compromise the integrity of the piece. I would think it would be similar to a roll bar wouldn't it?
Here's what I think would be the ideal solution - take a length of steel bar used for roll bars/cages, bend it so it curves the same as the factory bumper. Weld on the short legs from the old bumper that connects to the frame of the car. Then weld on some tabs for the bumper cover support or just drill and tap the steel bar if it lined up correctly. Wouldn't that work? I'm just not sure how much weight that would end up saving. JMFab says the stock bumper weighs 35 lbs. I'm guessing maybe 10-15 lbs.
But hey, even if it didn't save a ton of weight it would still give us more space to work with and more potential cooling paths.
I think the "roll bar" idea would work out the best. And that material can be bought for fairly cheap. Easy to bend as well if you/they have the machine to do it. You would probably save; like you said Chris, about 10 - 15 lbs. But the room that could possibly be gained would more than be worth it too.
But to me, I think the roll cage type bar would be better instead of trying to figure out angles and weld them with square peices of material.
I like the idea. Round tubing would seem the best to me than you could add on what you needed for plate mount, intercooler, or whatever. The weight savings and the room added I think would be well worth it.
What if you cut up your stock Front bumper support like this guy did on his 1g? This would still add some strength, and if you wanted, maybe add some 1/4in thick steel to strengthen it up.
It would be cheaper that's for sure. But I think a bar would be stronger and would give us more space.
I would call up your local machine shop or someplace that does roll cages, take them your stock bumper support, and tell them you want this in chromoly. I am sure they could fab something up for ya fairly easy. Should be much lighter and just as strong.
Where do I sign up for the "perfect driver/perfect drivers all around me" mod?
Yeah no joke on that one Chris.
Thats what I was thinking/saying earlier in the thread. I believe if you went with the "roll cage" type material on this. That would be the best place to go. They would have all the material and tools to do the job "right".
I wonder if we have some engineers on the site who could figure out how much "swiss-cheese" style removal you could do to the factory bumper without severely compromising its integrity. I'll bet you could do a lot to the faces so long as you left the top and bottom intact.
Otherwise, what about doing two small diameter (2") pipes across the front, truck style? Heck, leave the bumper cover off and do it up Baja style ;)
I never thought to look at some baja off-road style truck bumpers to get some ideas like that. Good thought man. At least it would be something to design off of for a fabricator you know?
Well, I had my IC guy cut out the whole mid section of the bumper (because of the 31x12x4 IC), and just leaving the ends so that you can still bolt it up to the car. And in between he welded a steel bar, and welded the nuts on top of it, so that I could still attach my bumper with bolts and using the steel "thingy".
Chris, if you want stop by and help me bleed the brakes and a clutch, I'll be glad to pull off my bumper and show it to you, heck even take some pics for the rest of you.
Bending the tubing is not that hard. You can buy a man. bender for like 350ish with dies. Cheap welder for 150-300, that would do the job. You just can't weld as fast with the cheap ones, because they do penatrate the metal as good. But if you are wanting to read about fab. and what not or even ask the best way to do something like this check out Shop - race-dezert.com site. Go in to there fabrications part. That site talks alot about fab'ing roll cages bumpers.Well pretty much anything. And to your ? about the what material to use. Use the round. The bends won't weaken the material. Also if you use cromoly it is more expensive but its stronger thatn just cold rolled steel.
Chris - Check out this front bumper on this 2G race car. Maybe something like this would be good as well. If it was on a race car, I think it would be pretty good. There is all kinds of room there. Well, more than what we are working with now. Just another idea man.
