Quote:
Originally Posted by VisionPaintball
what is the idle set switch?
thanks
It's a little toggle switch that tells the ECU that the throttle is completely shut. If incorrectly adjusted, it can hold the throttle slightly open or fail to tell the ECU that you've shut the throttle and you won't get injector shut off during cruise or properly return to idle speed. If I remember correctly, 2Gs do not have this switch. If you have DSMLink like me, you can toss the switch completely and just tell Link to simulate it.
