View Single Post
Old 01-21-2008, 03:00 PM   #6 (permalink)
Slippi84
Proven Member
Slippi84's Avatar
Region: Tri State
Classifieds Rating: (7)
Reputation: Slippi84 is pretty helpful and trustworthy
Quote:
Originally Posted by Gamble97 View Post
Why would the dry shot be a bad idea?
To the OP why not just save up and get dsmlink. It's more than you'll ever need.
I know I used to own dsmlink for my tsi problem is I"m NA
To answer your dry shot bad idea question because your relying on your stock probably old fuel system to supply enough fuel to run your normal load AND the extra nitrous that your injection into it. Same effect as running too much boost on a stock fuel setup. Thus is why you would only really want to run wet over a 50 shot because that way all the fuel you need is being injected threw the fuel solenoid the thing you have to watch out though is without a dedicated fuel setup your still relying on your fuel pump but atleast the injectors fpr and stock lines after your fuel T are elimated from the equation.
Online
Sponsored Links
