New motor bad oil leak above filter.
Ok just dropped my motor back in and got it all plugged up and went to turn it over to make sure everything was running right and heard dripping. Looked under the car and from the back passanger side of the motor above the filter there is a bad leak , it gushes out when turning over. This is one of the times i was not present and doing the work on the motor when it was being built. And as this is my first 420 build im not sure what the problem is , it looks as if there is a missing gasket almost. There are a few ( 4 i think) holes that look like a bolt could be run threw. Its not comming from the filter or sensor. In red is where the leak is comming from and where the line runs as if it should have a gasket. Any help would be great.
