View Single Post
Old 12-29-2007, 10:32 PM   #67 (permalink)
blcknspo0ln
DSM Wiseman
blcknspo0ln's Avatar
Region: Tri State
Classifieds Rating: (4)
A nice recommendation was to make sure the oil pump casing was flush to the front casing surface without any pressure or aid. I had to wiggle it a bit, but here she is. Again, blue loctited bolts to 18 ft/lb.
The oil pump gear has a slot that you have to line up on the shaft in order to slide it down:
I used blue loctite this time because it was a major PITA to get the red loctited bolt off. I guess it really does its job
Hold it down and torque the nut with a 12mm wrench to 28 ft/lb.
Another new alignment pin:
New gasket, I've gotten really good at judging the tackiness/time frame
____________________________
~Tom
Offline
[posts] [gallery] [blogs] Reply With Quote
Sponsored Links
