View Single Post
Old 12-18-2007, 03:12 PM   #126 (permalink)
tsiboosted
tsiboosted's Avatar
Region: Southeast
Classifieds Rating: (0)
Reputation: tsiboosted is an unknown
Quote:
Originally Posted by Slow old poop View Post
The best way to learn by yourself is to run in high gears. This will force you to maintain momentum through the turn because otherwise you will have to shift down. Eliminate first and second gear completely from your repertoire (except when starting off, of course).
For braking, always brake in a straight line, and get all your downshifting done BEFORE the turn. Don't worry about heel and toe. That's why God invented synchronizers.
Brake as hard as you can for a short a time as you can-this is called threshold braking. Never hit the brakes at any speed over 100mph (you'll eat up your brakes if you do). Just coast on down until you are under 100, then hit them hard. DO NOT eeeeease down on the brakes and hold them on for a long time, like you do on the street. This heats them up worse than hitting them hard. Get on, get off!
It's brake/downshift, lift off the brakes, turn in, ease down on the throttle, and accelerate through the apex all the way to corner out. In third or fourth gear, of course.
Also, learn the difference between fade and boiled fluid: If you have a hard pedal, but the car doesn't want to stop, you have fade. Most likely your pads are wore down. Change the pads. If your pedal goes to the floor, but pumps back up, you have boiled the fluid. Bleed the brakes at the next opportunity.
Good luck. Get instruction, too.
Good post Rich. ALWAYS brake in a straight line ALWAYS. I cannot express that enough. As just to ditto what he said, also get those downshifts done in this same time frame as your braking.
Also, I know the old drivers ed rule of 10 and 2 rains through some peoples minds. But to me and ALL of the instructors I have had over the years. A more prone hand positioning on the wheel is actually 3 and 9 o'clock. (for me) It feels as I have better control over the steering thus over the car and where I want it to go. Just something else to think about as well.
____________________________
~ Eddie Garrison
#32 Grand Bayou Race Series
Offline
[webpage] [posts] [gallery] [blogs] Reply With Quote
Sponsored Links
