Heres some more guys:
Sensors:
-Engine coolant temp. sensor: 15-29 ft. lbs.
-Fuel guage unit: 1.4-2.2 ft. lbs.
-Oil level guage mounting bolt: 9-11 ft. lbs.
-Oil pressure guage unit: 6-9 ft. lbs.
-Crank angle sensor: 7-9 ft. lbs.
Engine supports/cross members:
-Left engine suport bracket: 22-30 ft. lbs.
-Engine mount bracket to bracket nut or bolt: 12-19 ft. lbs.
-Center member install bolt: 58-72 ft. lbs.
Exhaust:
-Exhaust to manifold (N/T): 29-43 ft. lbs.
-Heat sheild to manifold: 9-11 ft.lbs.
-Exhaust manifold to turbo: 40-47 ft. lbs.
-Exhaust manifold to head: 18-22 ft. lbs.
-O2 to DP studs: 29-43 ft. lbs.
-O2 sensor: 29-36 ft. lbs.
Misc. Engine:
-Wastegate actuator: 7-9 ft. lbs.
-Check valve (Turbo): 22-25 ft. lbs.
-Timing belt rear cover: 7-9 ft. lbs.
-6-Bolt connecting rod cap: 36-38 ft. lbs.
-7-Bolt connecting rods: 18 ft. lbs. + 1/4 turn (torque -to-yeild bolts)
-Rocker cover: 2-3 ft.lbs.
-Spark plug galley cover: 2-3 ft. lbs.
Misc. oil stuff:
-Oil return line to oil pan (Turbo): 6-7 ft. lbs
-Oil pipe to engine (Turbo): 10-14 ft. lbs.
-Oil screen nut or bolt: 11-16 ft. lbs.
-Oil pump sprocket: 36-43 ft. lbs.
-Oil pump driven gear: 25-29 ft. lbs.
-Front case: 14-16 ft. lbs.
-Oil filter bracket: 11-16 ft. lbs.
-Engine oil cooler mounting nut: 6-9 ft. lbs.
-Oil banjo bolt: 20-25 ft. lbs.
-Oil jets: 22-25 ft. lbs.
Pulleys:
-Crank pulley: 14-22 ft. lbs.
-Auto tensioner: 14-20 ft. lbs.
-Timing belt tensioner pulley: 31-40 ft. lbs.
-Timing belt idle pulley: 25-30 ft.lbs.
Intake:
-Intake manifold stay bolt: 18-22 ft. lbs.
-Throttle body stay: 11-16 ft. lbs
Coolant Misc.
-Engine cooler pipe to engine front case: 29-33 ft lbs.
-Water banjo bolt: 25-36 ft. lbs.
Water Pump:
-Water outlet: 12-14 ft. lbs.
-Water pipe-to-engine: 10-14 ft. lbs.
-Water pipe-to-turbo: 25-36 ft. lbs.
-Water pump bolt (4T): 9-11 ft. lbs.
-Water pump bolt (7T): 14-20 ft. lbs.
-Water pump pulley: 6-7 ft. lbs.
____________________________
-Dustin-
92 TSi
92 TSi AWD *Dark Star*
