wishihadatalon
- 2,616
- 76
- Aug 18, 2002
Grand Rapids,
Michigan
Hack, normally when one rod goes, it's enough to make a smart person let out and not damage anythign else. Plus the power loss and drag in the motor from one bet rod would hinder performance enough to keep it from damaging anything else. Just like my friend who had a local shop tune his car and 2 times in a row he broke the #1 piston at the wrist pin from detonation. Everything else was okay. The #1 gets the most air from the way the intake is designed and runs the leanest. That's why EGT probes are recomended in the #1 runner since it will be the hottest. So your #4 going out is a bit confusing, but i would still blame it on pre-ignition or some sort of hydro locking. Heat would normally melt a small hole in the piston or burn up a few valves if that was the problem.
Are you sure about that? The knock sensor is on the number 2 cylinder. Jon at TRE was explaining to me that all of the air enters the plenum, goes all of the way back, bounces off of the back wall, and then gets fed into the #2 runner.
. But only because I've tuned nothing BUT cast on pump gas and run several setups at lower timing to over 40 lbs/min. If I hadn't I'd certainly take your word for it. You've put out certainly plausible evidence.
