I have no idea what to expect with the stroker with lower compression. I am hopefully shooting for at least 350 hp. I do have a set of 450's out of one of my old 1g's. Do you think those would be fine to use? What kind of fuel pressure are you guys running also because on my hahn setup with the rising fuel pressure I was at about 120 psi with 9 pounds of boost. I am definitely getting away from that high pressure stuff.
