View Single Post
Old 11-10-2007, 02:14 PM   #1 (permalink)
headsup7up
New Member/Lurker
Region: New England
Classifieds Rating: (0)
Reputation: headsup7up is an unknown
wont idle when cold and rough idle when warm
i read the vfaq and searched the forums but didnt see anything like my problem. i put a 6 bolt in my 95 talon and i got it to run ok but the idle is very rough. when i start the car the rpm goes up to 2500 and then dies out. the car seems to just turn itself off, theres not sputtering or anything like that. its as if i just turned the key off. when i keep the car running by giving it gas it warms up and goesgoes down to a very low idle, at times it goes down to the poin where the battery light comes on; when it goes that low it is typically followed by idle surge which goes upto about 2500 rpm then it goes back down. sometimes it even stalls. ive had more than a few peopel look at it but know one can figure it out. i dont know if it has anything to do with it but itruns the same way when i unplug the maf, isc and tps. when i adjust the BISS screw it changes nothing. also im using a 2g intake manny with a 1g t-body (i need the senor on the mani to past emissions. i dont know if that could be whats causing my trouble. any help would be great. thanks.
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
