Quote:
Originally Posted by spyderturbo007
Fuel cut has nothing to do with fuel delivery so you can replace your injectors and fuel pump all day long and it won't do a thing. Fuelcut is caused by hitting a preprogrammed airflow value hardcoded into the ECU's programming.
If you are running stock boost on the 16g, sounds like you have a boost leak somewhere.
We have a winner. Boost leak test time.
