Quote:
the reason why 95-96 models get the p0505 codes is that the ECU drivers are not strong enough to run the IAC. You can change everyone of your sensors 1 million times and it will always come back. The ECU is the ONLY thing that runs the IAC.
So going on what poonman said above, would getting a used 2g ECU solve the problem?
