View Single Post
Old 06-29-2007, 11:50 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #26 (permalink)
titogs95 Offline
Proven Member
titogs95's Avatar
Tech Posts: 486
Classifieds Rating: 2
Reputation: titogs95 is pretty helpful and trustworthytitogs95 is pretty helpful and trustworthy
Quote:
Originally Posted by Echo5Zulu View Post
How are you guys connecting the wideband gage to pass data to the palm logger? I saw that it was mentioned that you can do it but didnt see anywhere showing how. Do you run the out put plug wires from the gage such as (autometer or ngk) and splice in somewhere on the ecu wires or the datalogger cable???
Also you guys talk about using the egt input can you rig it to use the wbo2 input in the mmpc logger program where its supposed to be? Or do you just use the egt input spot and change its name and function in the logger? A write up or sticky on this subject would be great as a lot of people use the palmlogger and if you could just add a "cheaper" wideband gage like the autometer it would be great! Besides I could just upgrade from my autometer narrow band gage.
Thanks much.
Ok, All you need is an 0-5 Volts output of the wideband and connect it directly to the EGRT input of the ECU. Once done. You can read the voltage or A/f ratio accoriding to your preferences in the MMCD. Now, the formulas I posted is to read the A/F ratio once you exported the file to the PC. Grab the raw data of the EGRT and use one of the formulas.
More info let me know.
____________________________
ALEX - 91' TSI AWD EvoIII.
