View Single Post
Old 06-19-2007, 01:58 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #6 (permalink)
1998gstspyder Offline
Proven Member
1998gstspyder's Avatar
Tech Posts: 234
Classifieds Rating: 1
Reputation: 1998gstspyder is more helpful than not
Quote:
Originally Posted by wt71gas View Post
Set your tune as best you can for the higher boost settings. I have a fwd as well as an awd and I use a simple two stage MBC for the fwd. I run stock boost 1-2 gears and hit the switch so its full boost for third gear. You probably lose a little power on the tune for the lower boost but thats why you run the two stage boost controller so that you can lose some power to get some traction in the lower gears. I just run a simple two stage mbc from dejon btw.
nice thank you. thats just what i have to do i guess. where did you place the button and is it easy to toggle between the high and the low while driving
