Wideband sensor location - direct exhaust flow?
generalu
Jan 19, 2005
SoCal, California
Howdy, can someone provide some insight regarding how deep the sensor end needs to be in the exhaust pipe? The bung that was welded for me was a little tall so the end of the sensor stops right before the circumference of the exhaust.
The A/F readings from my wideband are different from what DSMLink is registering (which I know isn't always accurate) - so I want to be sure I'm getting the most accurate measurement possible. Will this give me a reliable reading?
I made a sophisticated illustration below. Thanks!
With the o2 placed like in the pic, it may still read the A/F but it may not be totally accurate, and it may not read the A/F "fast" enough. The exhaust gases need to pass over the sensor tip, not by it. I would have the tip of the sensor protrude into the exhaust stream at least a 1/4". I would change it.
